I guess some folk are unfortunate with picking up punctures, I went many, many years without getting one, only to get one last year after posting on the forum in a thread about punctures..... who'd have thought.....
There are folks that will claim they never ever, EVER, ride over anything..... well, unless you are superman/woman, I don't know how anybody can say that.... there is no way you can see every potential puncture creating object when riding at speed.
Failures normally occur when a puncture, or penetrating object has damaged the tyre, the driver or rider is unaware that the damage has occurred until the bike feels squirrely, by then it's usually too late.
If you ride on a tyre which is grossly under inflated for more than a short, a very short, distance, you will create some level of damage to the casing structure. This happens because of over flexion of the casing components, think of a piece of wire that you bend and straighten several times....
Yet people will blame the tyre.....
Another cause of failure, the cause of which is often never seen by the driver/rider, is air infiltration to the casing structure. This can be caused mainly by either fitting error, where damage to the bead occurs with a pneumatic or manual tyre fitting machine, or it can be caused by a penetrating object which having penetrated allows pressurised air onto the tread area of the tyre casing.
This kind of damage can result in a tread delamination which produces bulges or blisters. As these can be in the area of the original damage a separation can occur between the tread and the casing structure, leaving a large area of tread missing.
The other kind of damage is where a penetrating object cuts the tread over a wider area, when this occurs it looks much like many of the pictures posted on the forum where a gash is the result across the tread. If this is coupled with a puncture that allowed air under the tread structure, the results can be.... interesting.
Finally, an unattended puncture running at perhaps 15-20 lbs/psi can cause a major heat build up due to casing flexion over time, sometimes a very short time, sometimes long..... the tyre pressure can then go from the 15 lbs way higher... the rubber compounds are denatured and the tyre can fail catastrophically. This can manifest as delamination, blistering and many other signs.
IF you get a chance, when removing a tyre that has run flat and is being replaced, stick you head in and have a good sniff.... this can tell you a great deal about the tyre and what it has been subject to in its final moments..... the difference in smell between a new tyre and a failed tyre is educational.
So, is it Avon that have a problem with their tyres, or with their end users.... even the most careful of us can suffer a puncture and not know it until the tyre fails badly....... don't get me started on tyre damage due to suspension problems...... or bad balancing......
Six years of examining tyres EVERY day, sometimes six days a week tends to give you a heads up on impending problems.....
I'll be sticking with my Avons by the way......
Steps back and awaits ignition....
