So I start my bike up 2003/4? ST1300 and all is well, Idles at 2000rpm from a cold start as usual, the problem is after 3 minutes or so instead of dropping to 1000rpm it climbs to, 2500, 3000+.
There are 0 bars on the engine temp gauge so I think the ECU still thinks the engine is stone cold, and is giving it cold engine fuelling which is causing the climbing RPM as it comes up to temp.
The bike I will add, also seems to ride completely fine other than the very high idle making slow speed difficult.
Where do you think I should start? I'm not massively clued up on the cooling system of bikes but IIRC coolant pumps don't run until a certain temp is reached, meaning the radiator might not be circulating no matter how hot the engine gets?
