Odd noise in the front forks
Galesburg, Illinois
ST1100
I have a '94 ST1100 with a mere 50K miles on it, and I recent began hearing a clunking noise in the front end. I have checked and re-checked to make sure all the cowling and bodywork is secure and all structural members that support the instruments and headlight. Nothing broken or amiss that I can find. It is seemingly in the suspension. It only makes his noise when I hit a particularly rough spot or small hole, and apparently only on the downward or return stroke of the fork travel. Could it be a broken spring? Suggestions?
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
How old is the suspension fluid? I’d pull the forks and do a fluid R&R and overall/general inspection. Damper rod and anti-dive are possibilities. Report back.
You might edit your post’s subject line to include “ST1100.”
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
+1 on the anti dive mechanism on the bottom of one of the fork legs. Which leg depends on whether or not you have the combined braking system. Some parts are plastic and can wear
But there are other possibilities which are related to the brakes and brake caliper assemblies. Pad springs, mounting bolt bearings, SMC pivot mechanism (if you have the CBS model), badly fitting non Honda brake pads, .... . Of course it could be the forks, but it is always worth investigating brake assemblies for odd clunking noises.
builder309
Galesburg, Illinois
ST1100
I just replaced fork oil a year ago, so I don't think it's that. Will check the other stuff and see.
Montreal
2009 ST1300A9
Check the front wheel bearings. I had a clunk in the front end of my first ST1100 caused by a worn wheel bearing.
jfheath
John Heath
2013 ST1300 A9
000679
2570
Another possibility - just prompted by @Andrew Shadow 's suggestion is the wheel bearing spacer. A long tube that fits in between the bearings on the axle. It ensures that the bearing are not drawn together when the axle bolt is tightened. But it should be held firmly in place when bearings are installed correctly. If it is loose, you'll hear a clunk when you drop the wheel onto the floor onto its tyre from about 1cm . Or you will be able to stick a finger into the bearing and feel whether or not it is moving about easily. If it is, then the bearings haven't been installed properly, and will probably be due for changing anyway - as they will have been subject to an extra load from the side the axle was tightened.
Uncle Phil
4 ST1100(s)
002064
698
Another 'far distant' possibility is the lower forks are 'wallowed' out - but that usually does not happen on low mileage ST1100s.
Backstory - I was having my forks rebuilt and one of the bikes had this strange 'clunk' whenever I hit a bump.
Never could figure out what it was - and I looked and looked and checked and checked.
Kent at Atlanta Computrac (a great and honest suspension feller) was doing the work and when he checked the lower forks before the rebuild, they were wallowed at near the bottom of the stroke.
Needless to say, I had to find another set of fork lowers to rebuild.
London, Ontario, Canada
2004 ST1300
My two cents.
If its a clunk you may want to check steering head bearing.
Lift the front of your bike while on the center stand. I usually use a floor jack n block of wood under oil pan.
Once raised grab the front wheel n check for play. You may notice the clunk at that point. You can also check for that flat spot in the race of that bearing by turning the handlebars left n right.
Hope this helps.
Dave
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
Regardless of whether this is the actual issue in this case, I continue to consistently hear / read very good things about GMD Computrac.
Have for years now.
Uncle Phil
4 ST1100(s)
002064
698
Ok, but what do you mean by wallowed? Enlarged in an oval or just larger in diameter at the bottom of the tube?
'Reverse' leg calipers - the 'needle' showed a great difference in the bottom measurement.
"Wallowed out" is an old country term where I'm from.
I do not have a clue as to the precise shape of the enlargement because it did not and does not matter to me.
And to borrow a line from Forrest Gump - "That's all I have to say about that."
