Hi all. I am thinking about buying new front fork springs for my 04 ST. Does anyone know what the original equipment fork spring rate is? Thanks for the help!
The OEM rate is reportedly appx. 86 mm/kg. That is found on the Race Tech web site.Hi all. I am thinking about buying new front fork springs for my 04 ST. Does anyone know what the original equipment fork spring rate is? Thanks for the help!
Hmmmm, 0.86 Kg/mm perhaps?The OEM rate is reportedly appx. 86 mm/kg. That is found on the Race Tech web site.
As a comparison, the straight rate spring recommended by Sonic for the ST1300 is a 1.2 Kg/mm rate, almost 40% stiffer than OEM!Jeff, you are probably right. I was relying on memory.
That is why I think the Sonic Spring calculator is whack. If you choose Sport Tour, Aggressive Street, bike weight 721 lbs, it indicates 1.2 springs for the 112 lb rider on up to whatever weight you could possibly be. In effect, all riders should be on a SS 1.2 if you believe the calculator.As a comparison, the straight rate spring recommended by Sonic for the ST1300 is a 1.2 Kg/mm rate, almost 40% stiffer than OEM!
What is the sag now and how do you ride, solo or two up, rider/cargo weight?I now have proper sag on both ends......
If I understand what you wrote - you have more sag without a rider than with a rider? That is odd.I have about 3/4" front and rear, measured all the way from fully extended, to with a rider. That would be called "rider sag". The static sag, without a rider, is in the middle as it should be. That is with about 1/2 the rear preload cranked in. I still have more rear preload available for when I carry a passenger. Some will have other opinions on the right amount of sag, but IMHO this is just right. The bike sits at least an inch higher than before, which means the OEM springs had at least 1.75" of sag, probably more in the rear. That extra inch is now available for the suspension to work without bottoming.
My seat height is on the highest front and middle rear setting, and I still have no trouble reaching the ground with my 30" inseam and riding boots.
