Oil leak
Rhome Texas
2011 ST_1300 PA
9102
I'm starting to see some oil leakage at the side of my oil pan, trying to find part number for the gasket, looks like I'll be changing it soon. Anyone know the part number, looked on Honda Direct but don't see it on the diagram or listed in the gasket sets
Post a picture of what your talking about.
It’s very rare to have the pan gasket leak.
It may be something else that we can identify if we see what your talking about.
002760
Clean the area, go for a ride... see if it returns and try to track it down from there.
The temps are starting to drop, every year that transition of temperatures causes some leaks due to aluminum and steel parts with regards to the water pump to expand/contract at different rates.. so some coolant typically leaks from the drain hold on the lower right front side of the engine.. that is normal per the manual.. it can look like oil when you mix in dirt / grime from riding...
Oil pan leak on a ST1300? I guess there is a first time for everything.
After you clean the area, dust it with baby powder (NOT J & J - it's rumored to have asbestos in it :rofl1:). The powder will show the leaks better.
Bothell, WA and Surprise, AZ
2012 ST1300P ABS
8912
There is no gasket, I believe HondaBond is specified for the oil pan
