Or tinkering with primary circuits to begin with...... I just don't put a whole lot of faith in orphan electronics from the Chinese black hole of electrical bits.
sometimes (almost always) I need to warm up engine and also open paniers, topbox with the same ignition key while preparing to a ride. Now I can do it without shutting engine off )Quick connect key ring, so you can separate the bike key from rest of keys.
Correct me if I'm wrong, but that looks like 3 relays. Or is one OEM?
I added two high-current (40A) relays in the cuts of oem circuit (drawn in red color - one for ignition line, one for fan line). Third relay was in the wireless module already.Correct me if I'm wrong, but that looks like 3 relays. Or is one OEM?
Gotcha!I added two high-current (40A) relays in the cuts of oem circuit (drawn in red color - one for ignition line, one fan line). Third relay was in the wireless module already.
Low tech approach: Quick connect key ring, so you can separate the bike key from rest of keys.
Slightly higher-tech approach: I carry two key rings, each with an ignition key and a top-box key.sometimes (almost always) I need to warm up engine and also open paniers, topbox with the same ignition key while preparing to a ride. Now I can do it without shutting engine off )
by the way, I dont know why they (honda designers) didn't use relays for ignition key switch. All high current goes through it - horn, lights, fan, everything. With this mod there will be only few milliamps of current just to latch relays.Or tinkering with primary circuits to begin with...
Emm.. I don't know where is my spare key ring.. keeping it at home somewhere...Slightly higher-tech approach: I carry two key rings, each with an ignition key and a top-box key.
I can start the bike and open the luggage, and I also have a spare ignition key in case I lose one.
Nice!! How big is the fingerprint module? Mounting it near the right grip could make starting the bike more efficient. But your approach works for you and it's invisible which is pretty trick. I also get the reluctance to cut into the Tupp.Two relays, one small pcb kit and 30 min of time, thinking how to crumple wires.
My bike key is the only key in one of these:And of course, a tracker tag (using Samsung SmartTag here) for each keyring
seller has 3 sizes of fingerprint module - smallest one is 20 mm in diameter. But yes, I'd prefer to keep tupperware intact.How big is the fingerprint module?
That would be more convenient solution, agree. Some alarm systems have this function as I was told. Maybe it would be better to go in this way and also have two-way remote alarm system.My preference would be for a ~2' distance so that just walking up to the bike would turn on the IGN.
Simple: to keep it fail safe...by the way, I dont know why they (honda designers) didn't use relays for ignition key switch.
