Oxford grip cable placement
rogo
Duluth GA
'05 ST1300
000406
My wife had some heated grips under the tree for me. My 1st set in 35 yrs of riding.
I’m reading instructions on positioning and would like to see a pic of grip/cable placement before I start. Thanks.
WA
'13 FLTRX, '08 FXDL
Lucky you! I installed one of their models. Give me a few minutes and I'll get you some pictures.
WA
'13 FLTRX, '08 FXDL
IMG_20181228_133930383.jpgIMG_20181228_133947954.jpgIMG_20181228_134003867.jpgIMG_20181228_134307572.jpgIMG_20181228_134349114.jpg
I'm assuming you want a preview as to how you might want to aim those cables. I very much like how the left hand turned out. Was a little less thrilled with the right. I couldn't find a way to keep that cable a bit more hidden and still provide full, unrestricted, range of motion. I might try to reroute it someday.
rogo
rogo
Duluth GA
'05 ST1300
000406
I might have to dry fit throttle side multiple times before finding optimal positioning. Haven’t removed original grips yet so not sure how tight they are to work with.
WA
'13 FLTRX, '08 FXDL
I did the same. Mine slipped on easily without adhesive. The adhesive they sent with the grips broke loose (both sides) on my trip through the Yukon and Alaska just a few months after install. Maybe I didn't use enough??? I went with hairspray after that. So far, so good...
My wires leave the grip roughly horizontally pointing forward so the cable goes over the brake/clutch lever. I wire tied it much like James T. Kirk. I also used their mount and the clutch lever screws to mount the controller.
