Marshal & others:
This is how I had to notch my frame to get my Penske to fit:
This photo shows how close the shock fits but it does clear and has enough rotation range to rotate as much as necessary through out the entire travel of the shock.
This is a photo of what is known as a Torrington radial bearing. It consists of two hardened steel plates and the bearing. The top steel plate goes against the preload adjuster, then the bearing itself, then the other hardened steel plate, then the shock spring.
This last photo shows how I install and remove the shock. Take the side plate off that mounts the pegs. Rotate the brake line fitting shown about 5? counter clockwise to allow the brake line to clear and the shock comes out the back. The black duct tape is to keep from the pieces from skinning each other up.
Hope this answers some of your questions.
RDR
RDR
