Yes, rear brake. Haven't touched the front yet, on purpose. Riding today, it was intermittent, but one thing for sure, pressing the front brake handle does NOT produce any noise. When pressing down on the rear brake pedal, it's a momentary squeal,
not anything that sounds like a semi coming to a stop.
I had to go thru your article several times for it to make sense (must be your accent, and learning what words like doddle meant)
. But once I took the caliper apart it all made sense. I did have the wheel off which made it much easier for a first timer to work with it. I remember wiping off the slider pin, then reinserting, then pulling back out; it made a little suction sound, but it did move freely during the reinstall test per your article.
For the greases, I just checked and verified I'm using a high temp synthetic. That seems to be the anti-squeak piece, right? Maybe I didn't put enough of it on the back of the pads. I couldn't find the copper grease, but I remember shopping specifically for that type.
If my 'ignoring it' approach doesn't work, I'll take it all apart again and double-check everything, once riding season winds down.
Funny thing about my original post. I not only had a copy of your article, but a printout in the garage turned to the very page where it talks about testing the brakes. Aah, I need an assistant. A tall, buxom assistant.
