Using an article started some 10 years ago on this site, I decided to take the plunge and tackle fixing my pre-load.
Symptoms: only got resistance after about 13 clicks.
Diagnosis: probably not much fluid left in reservoir.
So read through the article and jumped in using the @Igofar method to avoid taking the knob apart. Got the banjo bolt off and tipped the reservoir over and very little fluid came out with a lot of crud but not dirty crud. Mostly the stuff you see in attached pic (seen at 12 o’clock).
After flushing a few times I was still getting chunks of these white solid flakes. What is it?
Continued flushing until this unidentifiable stuff was not coming out, filled and put it back together.
Testing repair: resistance still only after 13 clicks. What? Back to the article and realized I had forgotten to reset the piston. Got it sorted out and learned a lesson.
Final outcome: resistance after 1.5 clicks.
I am humbled and grateful for the collective wisdom on this site.
Many thanks to all who contributed to the article.
