Take a look at the second drawing referenced by the link. If you check the electrical analysis (right-hand side) of both the "Honda ST1300 Heated Grips..." and the "Honda ST1300 Grips Controller & Dual Star Heated..." sketches, you'll see that the two different grips have very similar values, if anything the Dual Star heated grips appear to have a slightly greater wattage (1%) than the OEM heated grips.I am kind of attached to the level 4 "Nuclear" heat of the OEMs
East,Just bumping this thread as the same has happened to my OEM grips which I installed. They worked for two years and now I just get pretty lights on the controller and no heat.
I've just had my OEMs die, less than a year old, I did the install so I'm not going to ask Honda for a refund. Electrics are not my strongest suit. Anna'sDad, the Dual Star heaters to Honda Controller schematic is awesome.Don't replace the Honda heated grips controller if it's not broken.
Instead, install a pair of aftermarket grip heaters, and a pair of new grips.
Look in the ST1300 Articles section for a..., never mind here's the link.
When I installed the Dual Start grip heaters on my daughter's Ninja I snipped the ends of the blue wires cleanly, used heat shrink tube on the ends, and lastly turned each wire back along the wire bundle and used heat shrink to keep it in place. I tried to indicate this in the drawing.1. What do you use to terminate the low heat, blue wires?
The OEM Honda grips and controller use single bullet style connectors, I usually purchase these and other connectors from Vintageconnections.com.2. Are there any special or unique plugs and/or connectors I should purchase at the same time I buy the heaters?
Thanks for the praise, enjoy your new heated grips.Anna'sDad, the Dual Star heaters to Honda Controller schematic is awesome.
I too had heated grip failure. The grips are in series and if one fails the they all fail. After using an ohm meter to determine that the left grip was the culprit, I notified my dealer. He tried to get it warenteed but Honda said no sail since it was not purchased with the bike. I had to purchase the whole set as no single grip could be purchased alone. Ken.
