PSR ST1300 ABS Dash Shelf available now. Introductory Price $59.95 until 3/15/19.
SoCalST8
Vendor
Los Angeles
ST1300, ST1100, R1
Limited Availability (takes 11 hours to make one)
For ST1300 Pan European ONLY
3D printed ABS material. 5mm wall thickness with honeycomb support.
Five vertical 1/4”-20 threaded through holes
Three front facing holes for auxiliary LED/signal reminder.
(build in wiring channels between front and vertical holes!)
No modification to stock dash
Compatible RAM ball part numbers: RAM-B-237U / RAP-B-379U-252025 Not Included.
No more than 2 attached devices recommended
Drilling additional holes on the dash shelf voids warranty
Please note irregular surface finishes are normal from 3D printing process
Designed and Made in USA
PSR ST1300 dash shelf ordering link below:
SRP $79.95. Introductory Price $59.95 until 3/15/19.
Thanks!
Charlie
236466236467
236468
Mounting Instructions:
  1. Raise windshield to its highest position. Or remove windshield
  2. Remove 8 plastic fasteners on the dash cover.
  3. Remove 4 screws from the front side of the upper dash face (2 screws on each side)
  4. Carefully lift up dash cover just enough to expose the two top mounting posts
  5. Install U-Clip/Nut provided in the two mounting posts.
  6. Reinstall top dash cover with 6 plastic fasteners and 4 screws
  7. Mount PSR ABS Dash Shelf by clipping the under side of the dash and line up 2 top mounting tabs to the top of the dash cover.
  8. Secure Dash Shelf with the 2 provided screws to the U-Clip/Nut mounting posts
  9. Install RAM Balls in desired pre-tapped holes, do not overtighten or the threads will strip and voids warranty.
  10. Make sure devices attached to the Dash Shelf do not interfere with any motorcycle operation and impede viewing of gauges!
  11. Check Dash Shelf integrity before every ride. USE THIS DEVICE AT YOUR OWN RISK.
Cleveland, OH
8907
Received mine today!! Outstanding packaging - very professional.
Really appreciate the sticker and key fob that were included!!
Can't wait till I get it installed. THANKS!!
T_C
St. Louis, MO
2005 St1300
8568
Dropped my order in last night. I see the price is still at the lower introductory level. If you were thnking about it... now is your chance...
It looks like a little LED light bar. Maybe for selfie illumination?
What's the chorus for any kind of new tech – I'd be concerned that it would distract...
