I've been using my fingers and a thin flathead screwdriver. My fingers get kinda raw and tired. What kind of tools are you guys/gals using to remove the pushpins from the tupperware on your ST's?
I use a small phillips head screwdriver to push the lock pin in, then use a tiny flat blade screwdriver with a 2mm blade to lever the thing out. For the protruding kind like in the inner and lower cowlings I use a small pair of pliers to pull on the head if it resists my fingers.
I can't say that I have them in and out so much if becomes a chore though.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
