I am trying to remove my radiator to get at the leaky hose clamps. Removed all the fairings and the 3 radiator mounting bolts. I am assuming the upper right mount is just a dowel the the right mount is inserted on and to remove the radiator you must drop the left side enough to slide off the mount? Is that correct?
2nd issue is the hoses mounted to the radiator. They are firmly stuck on. Any tricks to removing them without damaging them or cutting my hands to threads. I was trying just to drop the radiator slightly with the hopes I might have access to the clamps but so far cannot get off the right side rad mount with the hoses still on.
Thanks
Randy
Thanks
Randy
