Raer Wheel final drive coupling removal
PmodelinUS
Gages Lakes, IL
1993 Honda ST1100
000200
Ok, how do you remove the final drive coupling on a 93 ST1100. I have looked for videos with not much luck my manuauls simply say fit out however min eis not going anywhere. So what bit of simplicity am i missing. LOL. Thanks in advance.
British Columbia
2021 RE Meteor 350
Just pry it up gently all around the flange. It will slowly lift out. Protect the edge of the wheel from damage . I used the curved handle of the Honda pliers to get under it.
Northumberland UK
VStrom 650
Like Bush says the 5 pin Centre will lift out.
DON'T loosen the nuts.
Leave your nuts alone!
A small pry bar may be required.
Good luck.
Upt.
British Columbia
2021 RE Meteor 350
Thank you gentlemen
And . . . if you are intending to replace the rubber dampers and aluminum inserts (both should go hand in hand) now, or at some future point, you will, more often than not, need a rubber mallet to drive the pins back into the inserts to seat the flange. Use the proper Moly paste as required too.
