Re Goldwing tip over bars (again)
Duporth
Australia
2021 BMW R1250GS
I notice on my ST at the moment that the 10mm hex socket bolts, with which the tip-over bars are to be secured, are not located in the centre of the counter-bored hole in the silver side panel i.e. not concentric.
Help appreciated thank you:
Is this saying the 10mm bolt hole in silver panel is not in the centre of the bored hole - seems unlikely, or the 10mm hole is larger than 10mm perhaps?
Is the location of the bolt off-centre in the bored hole a problem for me fitting a neat bush, or is there some play room in the bolt position?
Cheers, D
Montreal
2009 ST1300A9
There is some play between the bolts and the bolt holes in the step-frame. If you loosen the bolts you should be able to align the step-frame with the sub-frame a little better to center your bolts. Bushings will fit in nicely as this is what I did. See the attachments here for pics.
Duporth
Duporth
Australia
2021 BMW R1250GS
Thanks very much Andrew. That advice is very helpful. I will proceed as planned.
Cheers D
