Rear Brake Caliper mounting bracket question
I just took the rear end apart and did the splines and installed new brake pads.
However, I'm thinking I did something stupid and need guidance:(
I used the Honda Moly paste on the splines and Red Mobil 1 synthetic grease on the Axle and brake caliper bolt. I also put some red grease on the two dowels that hold the mounting plate on with.
After washing up, I read that Silicone grease is recommended.
Will my Mobil 1 Red grease damage the rubber or anything else?
I'd really hate to have to take the whole dang thing apart again tonight:banghead:
Thanks in advance.
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
Yes, it will.
Not only do you get to take it apart, you get to figure out how to degrease the rubber parts without damaging them, and I don't have any good suggestions.
--Mark
002760
ooops... me too... didn't think it mattered myself... I guess about 10 Q-Tips should work.
002760
I'm assuming most auto parts stores will have silicone grease correct? Also assuming it will need to be in paste form.
Is white lithium grease close? I have some of that but in spray form.
002760
I guess I should just shut up and get the right grease.
I'll see what I can find later today. It looks like the boots just pop in/out and some q-tips should work fine for cleaning them out.
I'll update my post on Rear Brake Piston Cleaning w/pics of the grease and what I end up doing.
New Jersey
st1300 '04
7163
Might be called something different like brake grease in the autoparts store. You could get in in a scuba shop o-ring grease or maybe a camera store. A Hobby shop would probably also have it.
It wouldn't be in paste form. A little thinner than vaseline usually clear.
I've gotten blank stares in the auto parts place by me.
I might get in trouble here...but I think you'd be ok with dielectric grease. It may be a different viscosity but it's the same stuff.
Grease= oil + soap
Lithium grease would still have the oil in it. That can cause rubber seals to swell and distort.
002760
I wouldn't think so.. is dielectric grease for lubrication? I thought it was more for insulation and corrosion protection.
New Jersey
st1300 '04
7163
It's the same stuff but may have a different ratio of silicone oil (not petrol oil) and thickener.
Then again it may be exactly the same.
Silicone grease = silicone (polydimethylsiloxane) + thickener (fumed silica).
It is a lubricant safe for rubber. Including those LOL.
It's also an insulator (dielectric).
Because it coats surfaces it is also a corrosion inhibitor.
Technically it should only be used on connector boots to help them slide together and apart and also help the environmental seal. Like a spark plug boot, not on the connector contacts themselves. In practice the contact pins scrape away the grease and make a metal to metal contact surrounded by the rest of the contact which is protected from corrosion.
So for the brakes its a lube that doesn't degrade rubber.
The insulating property just happens to also be there.
Damages rubber over time? Don't like the sound of that.
I forgot I've got a small tub of the stuff in my Scuba/Rescue gear.
Thanks for pointing that out.
I'll be good to go tonight.
Tom Mac 04a
LI , New York
04 ST1300a
8347
Got a big tube from my dive teaching days...
BTW, you can also get it at anyplace that services/sells pool equipment as the silcone grease is used for orings on pool parts
Vancouver British Columbia
Use brake clean to clean all parts,lube caliper sliders with silicone brake grease both these items are available at your local auto parts store . Trust me i'm a mechanic!
I tried a pep boys, auto zone, winchester auto parts, napa, kragen, Ace Hardware and OSH! None of them had ANY product that said SILICONE and GREASE on the label!
All the brake caliper grease was the Moly, hi pressure stuff, either black, purple, or red.
Since honda calls for it in the service manual, I wonder where they expect you to get it?
the Dielectric grease in the link Mellow provided said it damaged rubber after a while!
I'll try a scuba shop or pool supply store tomorrow since my o-ring lube was for Nitrox and O2 applications.
The quest continues
002760
Actually, that link said it would damage silicone plastic, not rubber.. so I think that's okay.
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Silicone grease == dielectric grease.
Autozone sells dielectric grease in a pressure can.
Works like a champ; remember that a bit more comes out after you're done with the 'trigger' on the can.
New Jersey
st1300 '04
7163
Autozone has it.
http://www.autozone.com/autozone/accessories/CRC-8-oz-226-796-g-brake-and-caliper-synthetic-grease/_/N-268d?counter=0&filterByKeyWord=silicone+brake+grease&fromString=search&itemIdentifier=826455_0_0_
Fountain, CO
I've used Sil-Glyde for years on all my brake work (cars, bikes, etc.) Also is good for a multitude of other things. I get mine from Napa, but it's available other places as well.
Thanks, I picked up some sil-glyde at the local hot rod shop on my lunch break. I'll try it out tonight.
