Hi
I noticed my rear wheel would be stuck on when the rear brake pedal is applied.
After closer inspection i noticed the clamp that is nearest to the rear calliper that holds the brake line hoses and pipes secure to the swing arm has
snapped complete off and is not replaceable as it is apart of the swing arm so i secured it back to the wing arm with zip ties which for now has worked and the rear brake is running free again.
Would not have thought it would have made any difference but for some reason it has just hope the ties hold as its not far from the exhaust.
Can't believe its snapped away leaving the brake lines and pipes about an inch away from the swing arm.
Has this happened to anyone else and whats your thoughts on why the lines not being secured to the swing arm effect the rear brake.
I can see there are three points along the swing arm where the brake line tubes and hoses are secured just can't believe its snapped off.
thanks
thanks
