I recently removed the lower brackets on the sides of the bike to install a rubber heat barrier. All of this in an effort to stay cool....
I've now had the right bracket off a few times to get to the rear brake pedal.
I take the bike out and all seems normal, but then the after awhile the rear brake gets pumped up and locks. Actaully not only the rear the front too because of the linked sysytem. The only way to release it is to open the bleed valve on the rear calper. I called a trusted Honda Machanic friend and he says that with screwing around with that bracket I must have messed up the padal adjustment. He says there must be free play so when the brake fluid heat up it's not gonna lock down, like it is.. I've tried adjusting the padal but the only adjustment is to raise or lower the pedal. Is there another adjustment for free play?
I was able to ride it 40 mins. in town today before it happened. I had all the brake fluids changed last year and the bike is an 03. The last dealership that I had it into said he did all the recalls.. Although when I asked which ones, he said they were not for brakes. Did the 03 have the proportioning valve recall? One last thing, the bike has not been ridden since last Sept. Could there be a blockage somewhere?
I'm at my whits end and my week off is now over...... Any ideas?
thanks in advance!
Al
thanks in advance!
Al
