rear shock preload C-spanner size
Oman
ST1100AY
I need to buy a C-spanner to be able to adjust my preload, the Honda one isnt available over here so I figured I would look online, found this one and was wondering if anyone could confirm whether one of the ends is similar in size to the honda supplied C-spanner
paulcb
Celina, TX
'97/'01 ST1100 ABSII
8735
If you have the tool kit that came with the ST1100, have you checked in it? It had one. I can measure mine tonight, if I can remember! ;)
aSTerix
Oman
ST1100AY
Unfortunately I didnt get any tool kits with the bikes so don't have a way to adjust the preload, thankyou for offering to check the dimensions
paulcb
Celina, TX
8735
Glad to help. Here are a few pics with an inch ruler...
AA0C5A70-89C1-43B0-83F3-27A3999706FB.jpeg 8D92546A-8951-44D4-A1C0-42A7886C0516.jpeg
C63D7B34-F041-4F15-9B3F-6541AC7808EC.jpeg 5026E4AF-C820-4533-9F80-FC44175BCDCE.jpeg
paulcb
Celina, TX
8735
You're quite welcome. Let me know if you need any more, and let us know if yours works.
mayo ,ireland
1990 ST 1100
my c spanner keeps slipping off and the preload adjuster ,ive tried flathead with rubber hammer but still wont budge ,any advise please
cheers ,
im in ireland
aSTerix
Oman
ST1100AY
I managed to pick up the exact same one second hand using your photos as a guide, it fits perfectly, thankyou
It was very rusty but a quick trip to the blasters and a coat of paint and its better than new
aSTerix
Oman
ST1100AY
Maybe try grinding the edge of the "prong" on your C spanner so that it is a slightly sharper angle where it sits in the slot on the adjustment ring, you need to be quick and not let the C spanner heat up or else you will need to re heat treat it ! I have used a dremel before ( as opposed to an angle grinder) . Also, apply some oil to the adjustment rings beforehand if it looks dry (i.e. ungreased)
aSTerix
Oman
ST1100AY
..... the preload adjuster ,ive tried flathead with rubber hammer but still wont budge ,any advise please
Sorry if I'm stating the obvious here, there is the rebound adjuster on one side (top mounting) and the shaft locking screw on the other side. The shaft locking screw has been 'peened' into the mounting , you can see the radial marks, this wont move at all (and you don't want it to !!)
Assuming, you are trying to move the rebound adjustment screw, you need to try it clockwise and anti-clockwise until you work out where it is (it could be fully in or fully out) . The screw slot is wide and you might want to grind a bit or screwdriver to get a good tight fit (or get a Wheeler gun screwdriver bit set: these have just about every thickness of slot bit you could want)
