Rear turnsignal lens problem..cracking
the Ferret
Daily rider since May 1965
So-Oh
21 NC750 14 CB1100
005504
2006 ST 1300. I bought it new. 38,000 miles. always garage kept, never backed into anything, never been rear ended, never been on the ground, not even in a parking lot ie no tip overs, other than on trips never really been in the rain. Both turn signals lenses where they meet the tail light lens, spider webbing cracking.Does anyone else have this problem? Is it common? What could possibly be causing it?
left
right
rear
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
With all three bikes, and over 200K between them, I never saw anything like that!
Byron
Moderator
KY
6091
It could have something to do with the local environment, extreme cold.
Highrider
Part time mechanic
Barlett, Illinois
5560
Those lenses are made from polycarbonate that can craze and crack if exposed to oils or chlorinated compounds. The cracks are in the area that the sections were sonic welded together, those areas could have a lot of stress from the welding.
Have you ever had the rear light / fender apart for wiring in the rear?
Scooter
This space for rent...
Germantown, WI
2019 BMW R1250RT
5929
This was my first thought also. Also wondering if an impact to the nose of the taillight might have propagated the force to those areas. Mine doesn't show any of those cracks and I've never seen anybody else on the forum complain about them until now...
the Ferret
the Ferret
So-Oh
21 NC750 14 CB1100
005504
It's definitely weird. I thought maybe I overloaded the trunk or bags or something on one of the trips. There has never been an impact to the nose of the taillight that I am aware of. There have never been any harsh chemicals used on it. S100, water and Honda spray polish, that's it. Definitely perplexing.
the Ferret
the Ferret
So-Oh
21 NC750 14 CB1100
005504
Nope never been apart. I have a trunk, but it's not wired in.
Massillon, Ohio
2005 BMW RT
Mickey, have you ever slept near your ST? It might be from the decibel level and vibrations caused by you when you sleep. It's the only thing that's different then the others.
the Ferret
the Ferret
So-Oh
21 NC750 14 CB1100
005504
Lol..dang that is going to follow me everywhere from now on. No wonder every one says " No..our cabin is full " whenever I inquire.
BakerBoy
It's all small stuff.
Golden, Colorado
1408
Sonic welding isn't stress free and it should have been annealed to relieve the stresses. It appears that cracks in the joint also have spread out from the joints into the surrounding red and amber lenses, cracking perpendicular to the joint.
I doubt you could have affected the outcome.
First time I've heard of one here.
the Ferret
the Ferret
So-Oh
21 NC750 14 CB1100
005504
Well, regardless of cause, I think Culomorena78 (Mr. Turner) is going to fix me up and the back end of my ST will be back to pristine in the not too distant future. Thank you sir!
Jacksonville Fl
2004 ST1300
My pleasure. I purchased it originally with the intention of coming up with a way to make bright led lights work. I got as far as looking at it. Hope it helps you out and isn't too much of a bear to replace.
the Ferret
the Ferret
So-Oh
21 NC750 14 CB1100
005504
Looks like there are only 2 bolts holding it on from your pictures. Now where those bolts are is a mystery at this point lol.
New Jersey
st1300 '04
7163
Mine has had it for years. Doesn't leak so I don't worry about it. Not as bad as yours tho.
As mentioned polycarb is prone to stress cracking. Could be the cleaner you use, molded in stress when it was made, from the assembly process or uv. Don't know if it's molded as one pc or joined afterwords never looked that close.
(you can mold different colors with a 2 or even 3 shot machine) Unless there's a specific reason most buyers aren't going to pay to have molded parts annealed.
the Ferret
the Ferret
So-Oh
21 NC750 14 CB1100
005504
Carl, mine has been like that for a couple years as well, but seems to be getting worse lately. I have only used S 100 and water or bike brite ( same thing basically) and water, followed by Honda Spray polish about twice a year since new.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Since the inner rear fender is in the way, you'll pull the rack off, along with the rear cowl, which the light is attached to.
http://hamptonrpi.com/V4Files/Transplant%202004-to-2010/images/dsc00455.jpg
http://hamptonrpi.com/V4Files/Transplant%202004-to-2010/images/dsc00456.jpg
http://hamptonrpi.com/V4Files/Transplant%202004-to-2010/images/dsc00459.jpg
http://hamptonrpi.com/V4Files/Transplant%202004-to-2010/images/dsc00468.jpg
Sorry the pictures of the rear cowls aren't clearer...and I don't have any of the underside...I think there are three bolts that connect the rear cowl with the taillight.
