Yes, this is part of the challenge I hope to tackle this weekend.Key thing to think about is the cable routing for whatever you're charging.
I have a setup I can mount both phone and camera to the ball mount.Perhaps a more relevant question is - where will you put your phone / camera while they are charging ?
The Zumo 590/595 harness came with a USB charging lead and I thought - that's a good idea. Until I tried to use it. I ended up fitting one in the top box.
I once had a PTT button for a bike to bike intercom - it was supposed to fit on the bars. I was able to securely cable-tie that to a RAM ball mount fitted to the clutch lever clamp - like the one in your photo. I have also seen odd mounts for various devices that replace the brake/clutch lever cover.
Thanks, it is SAE, and I plan to engrave in my brain to disconnect it when I don’t ride, even though it has an on/off switch, which some claim still drain the battery.At the risk of repeating myself, ( and I'm SURE you know this) but for those who don't, the USB charger uses current even when nothing is plugged into it- make sure it is disconnected when parked or not being used.
If you loose that big old ugly piece of plastic you'll have options for lots of things!Sorry. I should have been clearer. No handle bar.
Something to consider I guess, though I'd like to keep the look as-is. I'll see, maybe at some point.If you loose that big old ugly piece of plastic you'll have options for lots of things!
Well, the big priority when i toured, was to b totally self sufficient. Lights, earbuds, batteries, phone all had to be charged off the bike. It was a wonderful feeling when i finally got to that point.Something to consider I guess, though I'd like to keep the look as-is. I'll see, maybe at some point.
Totally makes sense.Well, the big priority when i toured, was to b totally self sufficient. Lights, earbuds, batteries, phone all had to be charged off the bike. It was a wonderful feeling when i finally got to that point.
That's easy enough to confirm or dispel by putting a DDM in between a lead of the USB adapter and it's intended bike connection. F'rinstance connect the + lead of the adapter cable to the plus lead of the DDM and the DDM's negative lead to POS+ battery terminal. Connect the adapter's negative lead to the battery's NEG – terminal. Since it's a DMM polarity doesn't really matter.it has an on/off switch, which some claim still drain the battery.
