Welcome aboard. I did not know Honda marketed two different engines for ST's, but more knowledgeable people will be along shortly.
How do you know it is a smaller output engine? Owner's manual? Hearsay? Prev. Owner's declaration? I'm asking because a quick online search showed only one tuning for the engine. This is the first I've heard of a low output ST1100 engine.Thank you.
Probably it's the same engine just choked.
It's in the technical declaration of the motorcycle.How do you know it is a smaller output engine? Owner's manual? Hearsay? Prev. Owner's declaration? I'm asking because a quick online search showed only one tuning for the engine. This is the first I've heard of a low output ST1100 engine.
Good to know. Just wondering if it's possible to open it for full power.Interesting as I have not heard of a 'detuned' ST1100 and I've had ST1100s since 1997 (on this side of the pond).
The reason they set them to 90hp was for the European 'specs' IIRC.
I don't know what they would have done to restrict unless they changed the cams or something like that.Good to know. Just wondering if it's possible to open it for full power.
That tech declaration came from Honda?It's in the technical declaration of the motorcycle.
Glad you got an answer to your question.Hi guys, thank you all...I found a guy who has the same model. He changed the carburetor to normal and now has full power.
That's how they do that in Germany to get below 100HP (insurance class reasons), either restricted diameter carb boots, or mechanical restriction on the bell-crank...It could be just as simple as restricting the throttle opening in the throttle grip housing or carb cable attachment.
Thank you! So probably I need just to replace that plug not the whole carburetor?This is what the Magna inlet plug looks like . It's built into the Carb insulators
If that is what they did, looks like all you would need is 4 new carb boots for the ST1100.Thank you! So probably I need just to replace that plug not the whole carburetor?
