Methinks we've been over this in the past, but anyway
- got a Sony car stereo installed in both ST's, station & settings memory are parasitic load
- due climate/weather as well as job reasons bikes can be grounded for months at a time
- disconnecting the battery involves removing seat, LH pannier, gathering tools to unscrewing side panel fasteners, remove panel, remove ground cable...
I live in a building complex, vehicles parked in a huge underground garage, curious folks passing by, UN-mastered kids, (diesel) dust collecting, etc...
Disconnecting the battery by simply clicking on a fob would be a
very convenient method...
Another method I'm looking at is using a conventional,
mechanical battery disconnect switch, but replacing the toggle screw with a JIS/PH #3 and fumbling with the screwdriver through the gap between frame and side panel (still need to remove the seat, get a flashlight and named screwdriver though...)
Both methods, electrical as mechanical will further have to proof reliability in daily use down the road... hence must be easily rebuild-able with onboard tools in case of issues...
If this experiment proofs successful, I
might even
consider returning to conventional AGM batteries, but since those suckers always die of sulfatation I kinda fed up with those...
