So when you need a new batter, where do you buy one from? I need to replace mine and there’s so many on line places all with wildly different prices! Just need a good battery that fits at a decent price. Where should I turn to?
Thanks, it would appear their site is down, or jat least broken. I can’t access anything past the home page. Hopefully they aren’t another retail covid apocalypse victim.Factory OEM battery Yuasa Much cheaper than dealershipsAvid Cycles - AvidCycles
Avid Cycles is a family owned and operated motorcycle parts and accessory store serving the high desert. We carry products for all makes and models including KTM Kawasaki Honda Yamaha Suzuki Polaris Can Am Arctic Cat Husqvarna.www.avidcycles.com
Free shipping, fast service..
Been ordering stuff from this place for a few years, normally arrives the very next day!
What in the way of work was required?required some work to shoehorn it it, but will fit.
The new battery is taller than the stock one, so the original hold-down bracket will not fit.What in the way of work was required?
I would be surprised if you would notice a difference in cranking speeds with only 10 CCA more. More likely that you are noticing the difference between a new battery and an old tired one.And, because it's a bigger battery, electrically, it spins the starter faster than the stock batt.
(or maybe just faster than the 10 year old stock batt I removed.
Just a note to keep an eye on those cable ties. I find that the nylon ones (that is what yours look like) tend to just snap after a while when they are in high heat conditions like these will be. When I say a while, I don't mean weeks. It is more like months or more than a year, but they seem to just let go.So I used cable ties to secure the battery, and also to hold the fuse - as you can see in the photo.
The white ones are Thomas & Betts that I got from my work ( $$ ). So I think they'll be OK.I would be surprised if you would notice a difference in cranking speeds with only 10 CCA more. More likely that you are noticing the difference between a new battery and an old tired one.
Maybe just replace them at the beginning of every riding season as part of your start-up procedure.
