Re: Replacement for the Honda ST1300 in 2014?
If we rode BMWs, we'd be talking about expensive final drive rebuilds and failed ABS units, and undiagnosed computer issues and seized brake calipers and how our camp reading light that plugs into the accessory socket on the bike goes off after 10 minutes because the CANBUS computer cuts the power automatically -- all these interesting and expensive problems that the ST13 simply does not have.
Now I DO have a fuel gauge problem, so that DOES make me fell a little better. Just like my friend with the RT. Except that my problem is likely fixable for about $100, where his problem remains after the several visits to the dealer. So, I guess I'll have to enjoy it while it lasts...
In the 70's they did a study on productivity. They made incremental improvements in the work environment for factory workers (added better lighting, piped in music, etc.) and then measured their productivity after each change. And with every improvement, the productivity went up. And then they started removing the improvements. And productivity continued to improve, even though workers were no longer as happy.
It turns out that change itself was the important factor, not whether the change was actually benefitial, because it prevented boredom.
See, this illustrates my point perfectly. Lube the windscreen track once in a while, replace the OEM hose clamps with those friction locking clamps from Napa, stick your fingers in the hole when you are changing the rear tire and replace the bearings if they feel notchy -- all of these are simple fixes. And the total cost of all the aforementioned fixes is about $100.Well except for the probable failure of the windscreen mechanism, the high probability of leaking hoses, weeping water pump and premature failure of the rear wheel bearings, it's almost a perfect bike.
