PoppaCross
Vendor
Replacement mirror glass for Honda ST 1100/Pan European ST 1200 ST 1300
$75 US
Overseas shipping extra, email for a quote
NOTE This is the glass insert only! If your mirror body is damaged, I can’t help you.
But, In my experience with this machine, the mirror bodies are somewhat bulletproof.
I love my ST 1100. But like all antique motorcycles, sourcing body parts can be an issue.
The first time I had to replace the left side mirror I searched for a year and then had to result to old stock new parts at a stiff premium. Like $120 + if you can find one!
Now on the second time around, I found a local manufacturer to cut the glass insert I needed and was able to get the job done for half the cost. My partners still have the template so now I am your source for ST 1100/Pan European replacement mirror Glass.
I have a left and a right-side side plate in stock. I can have as many as needed cut to order.
Installation is a snap.
First, dismount the mirror body from your machine and remove all broken glass.
Second heat the plastic portion of the mirror assembly with a hairdryer or a heat gun. Don’t use open flames.
Third, put four dime-sized dollops of two-part epoxy inside the plastic mirror assembly.
Fourth. Insert new glass and hold it in place with rubber bands. Let set overnight.
Fifth, remove the plastic shielding I shipped your new insert with and the rubber bands.
Sixth reinstall your repaired mirror.
Now go ride.
This is my Esty shop
$75 US
Now go ride.
MotorcycleMirrorFix | Etsy
You searched for: MotorcycleMirrorFix! Discover the unique items that MotorcycleMirrorFix creates. At Etsy, we pride ourselves on our global community of sellers. Each Etsy seller helps contribute to a global marketplace of creative goods. By supporting MotorcycleMirrorFix, you’re supporting a...
www.etsy.com
