Have you looked at the rechargeable air compressor from MCRider? The most affordable item in the video.
I had a flat in my car and used Slime to get home and see if it lasts. It still was leaking a bit, so I called my tire repair guy (also rides M/C) and he said bring it right in. As he was getting ready to take the tire off, I told him I had put slime in the tire. He was about to kill me. He slowly took the tire off and with so many paper towels he sopped up the slime. Then he dried it with a compressor, then cleaned it with soap and water, then dried it again, then took his angle grinder and took off a thin layer of rubber where the inside patch was going on. He told me that nothing sticks to the rubber, no matter what you do, if you use any slime type flat repair compound; it always failed. So lesson learned, I only carry tire repair worms, and rubber cement (and a 12v compressor).I had an experience with Ride-On that may be of some interest. Apparently it doesn't seal well on a wet road. I experienced a rear flat not long after riding through a moderately heavy rain. I had Ride-on in the tire, and when I looked for the puncture, I found Ride-On plastered over the inside of my fender and dropping off in big globs back onto the tire. I plugged the hole, but the plug came out a couple days and about 150 miles later. Replugged it, and it came out about 60 miles later. Kept replugging and the tire kept spitting them out--with or without rubber cement, single or double plugs. Had to bite the bullet and get it towed for the first time.
