- Joined
- Sep 16, 2018
- Messages
- 414
- Location
- Northern Baltimore suburbs
- Bike
- ST-1300A '09/'12
- 2024 Miles
- 000298
Not exactly sure what you mean. This will depend on they are wired. I used relays that are dependant on how the state of the switches. So however the switches are when the motorcycle turns on, that will determine which lights are on/off. The Zmoons are just lights with one wire for each color light and one for ground. How you wire them is up to you.First, if you set them as yellow and have them on when you turn off your bike, will they be on and yellow the next time you start the bike? The lights I ended up buying need to be turned on each time I start the bike.
If you are talking about the Zmoon wiring harness, I can't help you much as I've not used it. I did have a similar funtioning harness for a different brand lignt. If I remember correctly, once power was restored, they would recycle to their primary state which was everything off. I can't remember for sure as I never installed it.
The main puropose of the Skene controller is to dim the lights. You will have to get a switch to control this. I suppose you could program them to be on with high beams and off when low if you really don't want to use a switch.Second, does the Skene controller do more than consolidate where you power the lights and act as a switch?
The controller will act as a relay so you don't need to instal one. Maybe that is where the confusion is.
You can refer to the following install instructions for more reference:
*Edit* I just read your follow up post and since I didn't use any included switch system, my lights just stay in the same state they were when turned off.
