just bought an 2001 its running a little rough and popping back through the air box, I did notice that the fuel tank has pressure when I remove the cap is this normal? the PO replaced the air filter with a K&N, and it also had delkevic exhaust don't know when the exhaust was replaced, it only does this when the engine is NOT under a load, going up small hills or steep hills seams to run fine going to check air filter and plugs, I did put some sea foam in it however I have only got to ride about 50 mile (been raining a lot here) Just wondering if anyone else has had this problem? and what to check for? thanks in advance for the help!
