Screw in phone/ gps mount
The hole is tapped for a 1" Ram Mount ball. A variety of options are available to you. I typically use a short arm with diamond base ball to mount a GPS cradle or a short arm and X-Grip for a phone.
Nashcat
Theta TN
2015 Versys 1000LT
8591
Here’s a link to what you should need. It a 1” ball (B size) with a 3/8-16 thread. Remove the large center screw to verify it’s a 3/8” thread. Then you’ll need a double socket arm and mounting plate, of your choice from the RAM web sire. Stay in the “B” size accessories to make sure everything Is for a 1” ball. If, by chance, your thread isn’t 3/8, RAM sells several, with different threads.
Adapter ball 1”
Happy Rob
Happy Rob
Rob
CBS, Newfoundland, Canada
2004 ST 1300
8931
Almost perfect phone mount. I purchased this phone mount in Wish for $28.00 delivered to my door, Cdn dollars. It is great. Screws directly into my MCL bar riser. Wireless charger plus USB port. The phone is mounted securely with screw in sides. Easy on easy off and plenty of fuses wire to reach battery. Screw the stem into bar riser spot,then the round parts screw to the stem. Wicked dealScreenshot_20200916-081917_Wish.jpg
