Gus1300
What exactly is wrong in the picture? For those of us who can't tell by just looking...Took the rear caliper out a pulled it apart.
Found this---
Found this---
Don't know the details. Looks like a few guys on the ST EU board got together with a spring manufacturer and had a batch of them made a few years ago and the ones who have been using it since then just swear by it. I suppose you probably follow these EU characters as well?An interesting thought, but I'm not sure how you could arrive at that conclusion without parallel experiments.
Am not good enough with springs to figure out if it is is stronger just by looking at it. More coils makes it weaker (lower rate) but the larger wire makes it stronger, hard (for me) to know which way it goes without running the numbers, and then there is free length vs installed length. It could have been designed for about the same force but lower stress than the OEM, to prevent setting and weakening over time.But the stronger spring may have some merits.
Found this---
stopper bolt is "crooked" ... @jfheath explains in the post that follows, but it's pretty obvious ...What exactly is wrong in the picture? For those of us who can't tell by just looking...
Thanks, saw that, but the head flange also doesn't look like it's flat against its mating surface. It looked to me like the bolt is just sitting off kilter, not bent. Wasn't sure that's what I should have been looking for as there's no way to tell whether the hole size is allowing that play or whether the hole itself is not oriented at 90 degrees. Or that it was crossthreaded as explained. (I focused on the picture vs the text...)stopper bolt is "crooked" ... @jfheath explains in the post that follows, but it's pretty obvious ...
Could you please post a link to that EU ST board ?the ST EU board ......
Not sure about policy for posting links to ST boards here, but a search for "Forum for Pan-European" will get you right there.Could you please post a link to that EU ST board ?
Larry (igofar) is probably smiling right now. He must have sensed this question by now. He's the brake whisperer.Afternoon all. This is my first post.
Joined the forum to attempt to tackle an issue I’ve had with my 2010 ST1300A. I have a sticking rear brake that seems to be a regular issue on these bikes.
So far, I’ve replaced the rear brake pads and rotor, and rebuilt the rear caliper, bled and refilled the system following the service manual instructions. Still have the same issue with it sticking.
From what I’ve read here so far, it appears the secondary master cylinder and proportional control valve could be the issue?
Any help would be greatly appreciated. I’ve unfortunately only been able to get about 500 miles on this bike since I bought it.
How did you know?Larry (igofar) is probably smiling right now. He must have sensed this question by now. He's the brake whisperer.
Your issue is more than likely your SMC. Search it on here and ask or call Larry for some advice.....
Standing by the white courtesy phoneAfternoon all. This is my first post.
Good afternoon, @Jersey47, and welcome to the forum. Sorry to hear you are having trouble with your new-to-you bike. It sickening when you spend money on a new 'toy' and it doesn't live up to your expectations. But believe me - it will. And in the hands of someone who will look after it, it will do so for many tens / hundreds of thousands of miles.Afternoon all. This is my first post.
That is the commonly held belief. It's not my experience though, and. I would suspect not a common experience for members on this forum - once they have sorted out any issues created by poor maintenance of a previous owner.I have a sticking rear brake that seems to be a regular issue on these bikes.
But you managed the last mile home. That is the most important one.I’ve unfortunately only been able to get about 500 miles on this bike since I bought it.
Hi to ST Owners - my first post.I'll answer that for @ojm Larry - since he is in Europe
Oh, Welcome @ojm. I missed that it was only your 2nd post.
There are a few good places in Europe. This is one that I have used in the past.
Genuine Honda Parts & Spares - UK & Europe's #1 | MSP
Shop Honda parts and spares from Europe's largest spare parts provider. Fast and safe delivery worldwide from reliable couriers.www.motorcyclespareparts.eu
Please note - you list your bike as a 2005 model, but check the white label on the frame under the seat - my guess is that it will indicate a 2004 model. In which case it will state ST1300 4 or ST1300A-4 (the letter 'A' indicates whether it has ABS or not). If the label says '4' or 'A4' you need to give 2004 as your bike's year.
The website doesn't list a 2005 model, and I know that there was not a 2005 model in the UK. It might have been built in 2005, but using the 2004 specs. All models up to 2006 use the same L Brake caliper.
You need the complete part - labelled on this diagram as #2 - I've highlighted the outlined bit - it comes pre-assembled. Check the diagram for the details that you enter onto the website.
You will find it under the section 'L Front Brake Caliper' after you have entered the Brand, Type, Year, Model.
I went with the "buy-a-new-one" plan, and am glad I did.The SMC is a good bit more expensive than the part #20, but nothing more than a few tanks of fuel would cost you. Replacing part 20 - commonly known as the service kit - it is quite possibly not going to solve the problem. The SMC piston bore could be damaged by corrosion or the very very tiny compensation port could be blocked with crud - and the filter part with its own tiny compensation port, two very find gauze filters and a small spring and seal are not listed as replaceable parts. You may well have to buy the full unit anyway.
Or the bore could have been knocked out of shape.
The circlip is notoriously difficult to get out and in. Buying the complete unit does away with all of the hassle.
I actually rode mine for about 8 to 9 months, with no brake issues either. I was "going to get around to it" too, but we basically have about 364 riding days out of a year, here in Alabama, ...so I didn't find my 'roundtuit.<SNIP>
I have no excuse for not bleeding brake system, except "if it works, don't fix it". I will be changing fluid regularly from now on. The truth is, I didn't notice any problem with my brakes.
After draining and taking my calipers apart, it seemed like I might have run into problems in the near future, however, since the pistons seemed pretty hard to move. I was able to get them out with air pressure.
<SNIP>
