If a clearance on a particular valve is out of spec and requires a shim change to bring it into spec, does it make sense to pick a shim that sets the clearance at the high end of the spec rather than at the midpoint of the clearance spec?
I am assuming that, as the mechanical parts that affect valve clearance wear, the clearance gets smaller (correct?) so the upside with setting it at the high end means the valve clearances would stay in spec longer.
Is there a downside to setting the clearance at the high end of the spec?
Thanks in advance for the input.
Dudley
97 ST1100
Dudley
97 ST1100
