Okay, here goes..
Step One - Remove cheekpads
- This is pretty easy - they just snap in/out
Step Two - Remove inner foam
- This is not so easy, on the RF1000 turn the helmet over and pull up on the back of the side skirts - there are tabs that will pull out and you might need a little pressure to get it.
- Then, take a butter knife and try to break look the glue that is attaching the front foam to the chin of the helmet (see dark colored glue in pic below)
- Once the front glue is broken loose, you should be able to slowly start pulling the chin foam downward. BE PATIENT, it will slowly come out and you might need a little pressure but it's more important to work it a little at a time. Once you get the chin foam to a certain point, the whole front section will pull out and this is what it looks like:
Step Three - Cut Speaker Holes
- This is what I did, I lined up the speaker to the hard plastic section where I wanted the speaker to go
- Using an Xacto knife I cut the shape of the speaker into the plastic
- Then I cut, removed, then cut into the foam
- Now from the foam side of the hole, slowly cut it until you can snugly slide it into the hole and flush with the black plastic on the other side
Step Four - Cut Hole for Microphone
- Line it up where you want it and start cutting, I made mine fit flush against the chin from the inside
Step Five - Hook up wires
- Some people run the long speaker wire along the back of the helmet, I ran it this time along the front.
Step Six - Re-install all foam
- This can be a little taxing so BE PATIENT, dont' force it much. Angle the foam and get the right or left in fist then work the front in and you'll be able to force (JUST A LITTLE) the remining side in.
Now, I'm sure there are different ways to go about this and some techniques are better than others so the key is to be patient. Also, do this at your own risk, this is how I did my headset install and if you mess up your foam, headset, or helmet I'm not responsible (gotta have a disclaimer huh...)
If you need some help with something feel free to post and I'll do my best to provide some advise.
