sherob
Old Herder of cats.
FYI...
XM originally had 2, they now have 3. (And actually depending upon where you are you can get better coverage from one sat versus another under obstructions.)That would be because of XM's ground repeaters. They have them in large metro areas. I lose XM when I go under bridges in Pensacola but that is probably because we don't have repeaters. The bridges and Sonic awning block the line of sight to the sats. It has nothing to do with number of sats. XM has only two and Sirius has three. XM's are all over the equator and are geostationary and Sirius's are geosynchronus over the western hemisphere
I know that you said something about repeaters before as I had already read that by the time you posted that to which I was replying. My reply said that losing the signal doesn't always depend on where the sats are in relation to you on the ground (coverage.)XM originally had 2, they now have 3. (And actually depending upon where you are you can get better coverage from one sat versus another under obstructions.)
As far as repeaters....I sort of already said that.
https://www.st-owners.com/forums/showpost.php?p=187969&postcount=6
BTW, Sirius has ground repeaters as well, XM just has more.
Repeaters do not do any good to those not near repeaters, I for one am getting very tired of loosing reception everytime I go under trees.BTW, to explain the 3 versus 2 comment.
Sirius still has better sat coverage because of how their birds are positioned. Overall XM gets the best coverage because they have 10 times the number of ground based repeaters.
You should have no problems under trees.Repeaters do not do any good to those not near repeaters, I for one am getting very tired of loosing reception everytime I go under trees.
Yes, what antenna do you have?Rob, are you suggesting that an antenna change can improve reception?
I live in Spartanburg, SC, which is in the northwestern corner of SC. I have used several different antennas over the years. I used the big stock antenna (the size of a computer mouse) with so-so luck, terrible when driving due south and trees are on my right (west). Going the same exact route, but going north, gave me better receiption....as I was further away from the trees (freeway driving).You should have no problems under trees.
Where are you located?
Where is your antenna mounted?
Did you shorten the antenna lead or buy an altered antenna?
The smaller unit like the MyFi don't actually supply as much power to the antenna. You may want to try the clip antenna on your shoulder, as that seems to work for some.When I'm zipping around the moutain roads, I'll have to switch to the "memory" mode and listen to the playback feature. If the Myfi didn't have that option I would have gotten rid of it long ago. Even still, I am thinking seriously about updating to iPod or MP technology.
