I think I may have found the culprit behind my '94 ST1100 clutch slipping. A stuck thermostat. When the oil is too hot, the clutch slips. Thoughts?
I ruled that out by changing to the recommended, Honda OEM oil - to no avail.Wrong oil.....
Not knowing the type of hydraulic fluid in 0lace from the previous owner, I flushed they system, rebuilt both the master and the "release", and used DOT4 fluid. I also replaced the clutch plates and the springs. Everything worked fine - until the engine got too hot. Then the clutch slipped just as it had done at the outset. What's too hot? I don't know in degrees, but once the temp gauge gets to halfway, the clutch slips. I grounded the sending unit to the fan to make sure the fan was functioning. It kicks-in when the temp gauge gets a little above half. I then opened the thermostat housing, removed the thermostat, and found that it was frozen in a slightly open position. I'm awaiting a new one and hope that it solves the problem. Fingers crossed.More likely that the excess heat is vaporizing the moisture in the clutch line causing it to expand and release the clutch a little.
When was it last bled and flushed?
I've never heard that overheating causes clutch slipping (but then, I'm not an expert in this area). If the oil is overheated, I would expect it to thin out, lose viscosity, and allow the plates to still function as designed. From what I know about clutches and thermostats, there is no reason at all why a stuck stat should affect the clutch. What kind of riding were you doing when this slipping occurred? Were you shifting a lot, slowing and accelerating on curvy roads or doing a constant speed on a highway?But I'm curious. Have others encountered this issue?
