The post with the capital letters is the best brand to buy according to Red Green, the uncapitalized is for less critical repairs.
Non-OEM stuff? Not unless you count the 3 sets of forward aux lights, aux rear lighting, aux fuel cell with attendant lines, shut offs, and pump, the gps's, radar, pegs, hydration system, custom tool box at pillion seat, and a couple of other things I'm forgetting just now. Other than that there's nothing using non-oem fasteners.Unless you've added non-OEM fasteners to your bike, you have no need for a 9mm, 11mm, 13mm or 15mm sockets or wrenches.
I have to add the RAN list to my list!!!....... take a copy of the RAN list.......
Worry less, ride more.
Larry, reframe it, you GET to carry parts!My really-honest feeling is that I'm riding the wrong bike if I have to carry spare parts.
You need some 2.5 or 3 mm dyneema rope. Very small diameter but rated at 2,500+ pounds.I bought a little camera bag. Inside it has a stanley folding plier mutlitool. A tyre plug kit. a small set of of heatshrink solder connectors. A blowtorch lighter for the connectors. A pickup tool and inspection mirror and mini magnetic screw tray. A slim powerful torch. A mini bahco socket set to which i added JIS bits. A jumppack and some phone cables. Under the seat i made the space bigger allowing changing the rear bulbs via under the seat there lives an air pump. Mounted somewhere is a wrapped spare key. in the front left pocket lives an alan key to get to the spare and a mini set of broken key removal tools. That way if i snap the key or lose it i can get the spare and use the tools to remove the broken part. I also want to add 1800lb pull line for towing but i cant get it in the uk. I carry most of the stuff to help mates
How about heavy duty tubular webbing - the kind used by rock climbers?I also want to add 1800lb pull line for towing but i cant get it in the uk.
Check at an electrical supply shop?I also want to add 1800lb pull line for towing but i cant get it in the uk.
Awesome thanksYou need some 2.5 or 3 mm dyneema rope. Very small diameter but rated at 2,500+ pounds.
Age may kill a shock, but so will overloading the bike to the extreme (even though it's been done many times) on a long trip.A lot of good suggestions in this thread.
<SNIP>
Fuel pump? shock? Brake pads? Thermostat?
For me no way. However, I can relate to the level of concern and advantage of having these subjects covered.
<SNIP>
Shock is probably good for 70,000 miles, and likely more, but age might kill it sooner.
<SNIP>
