Question for you John (
@jfheath);
I understand how a speed bleeder works, but I have never used one. I have also never used any check valve when bleeding brakes, such as the often mentioned Motion Pro.
Having no experience with them to draw on, and therefore not knowing what pressures they open and close at, I am asking the below based on the theoretical.
For discussion purposes, let us exclude the issue of air ingress around the threads of the bleeder screws when they are in the open position, be they the traditional or the check valve type.
Using a traditional bleeder screw, the brake lever is applied and held so that pressure is built up in the system before the bleeder screw is opened. The bleeder screw is opened, fluid flows out and the pressure drops. It is closed before the pressure has been completely dissipated. Closing the bleeder screw prevents any air ingress through it. This would be one cycle.
During this process, the brake lever is held in the applied position while the bleeder screw is cycled. This keeps the piston in the master cylinder in a position that blocks the compensation port throughout this process.
If the speed bleeder is functioning properly, it causes pressure to be built up in the system until it reaches a level where the spring in it is overcome and it allows fluid to flow. As the fluid exits, the pressure in the system drops. Long before complete dissipation, the spring overcomes the fluid pressure and closes the valve to prevent air ingress through it. This would be one cycle.
During this process, the brake lever is held in the applied position throughout this entire cycle just as with a traditional bleeder screw. This method also keeps the piston in the master cylinder in the applied position throughout this cycle. This is the same scenario as what happens by opening and closing a traditional bleeder screw, only it happens automatically without user intervention.
They both are;
- forcing pressure to be built up in the system.
- maintaining that pressure throughout the entire cycle.
- maintaining the brake lever in the applied position throughout the entire cycle.
- allowing fluid to exit through the bleeder screw.
- preventing air ingress through the bleeder screw.
What is the difference between manually opening the bleeder screw versus it happening automatically?
The only difference would seem to be that the traditional bleeder screw must be manually manipulated to achieve the above, whereas the speed bleeder opens and closes automatically without user intervention.
The result is the same is it not?
If there is a difference and your theory is correct, this would mean that the speed bleeder's only advantage is that they are easier to use, but they are less effective.
If that is the case, then all of the check valve type bleeders would be subject to the same deficiency, including the Motion Pro check valve that is much touted on this forum as a God send.
