Unless not recommended, I plan to use a vacuum pump and bottle kit.
Do you happen to remember the size?
Larry, I think it's 6mm but don't quote me.......
You just need the bottom grey lump off, which will come off in one lump. If you've got fairing extenders you'll just need to remove the bottom fastening on those. Also the bottom screws on the front cowling panel will need loosening to let the grey lump fall out.
Did mine this week, no vacuum required it just gushes out, like Roger says keep the master full and put something over the tank etc,........ Just in case.
Good luck.
Upt'North.
