ST1100 Clutch Replacement
paulcb
Celina, TX
'97/'01 ST1100 ABSII
8735
I'm thinking I want to replace the clutch on my 2001 ST1100 with 158k miles on her, commuting being about half of that. FWIW, I've done several automotive clutches, but never a motorcycle clutch. A few questions to those that have done this...
  1. The Honda manual says I need to remove the right exhaust. Is this a requirement?
  2. I plan on replacing the springs and friction discs, but should I replace the steel plates as well?
  3. Sourcing OEM parts from Partzilla will be ~$400, including a new slave cylinder (not sure I'm replacing this, mine seems fine and it's $108). Can anyone recommend a source for the complete kit, i.e. EBC or such?
I don't have any problems now (no slipping under heavy load) but engagement seems to be further out, and I've got the 7 day LDX rally this summer and don't want to be worried about my clutch. This is my list so far, what am I missing other than maybe exhaust gaskets?...
Spring22401-MT3-000 5
End Friction Disc22201-MA7-000 2
Friction Disc22201-MY3-000 8
Steel Plate22321-MT3-000 9
Cover Gasket11342-MY3-000 1
Slave Cylinder22860-ML7-010 1
CSC Gasket22862-MGJ-D00 1
Oil Seal91204-MB0-013 1
Comments/suggestions are much appreciated.
Richmond, VA
'01 & '96 ST1100s
9007
I haven't done my ST, but I did rebuild the clutch on my '73 CB750 years ago. I did not replace the steel discs.
Do remember to soak the fiber discs in clean bike engine oil for perhaps as much as 24 hours before assembly.
ReSTored
Mississauga, Ontario
2019 Tracer GT
4463
I guess my question would be if no slippage.............. why would you want feel the need to do this at all?
Nothing wrong with proactive preventative maintenance, but if no real issues with the clutch, why are you feeling compelled to do anything.
paulcb
paulcb
Celina, TX
8735
We’ll, that’s a really good question, glad you asked.
I’m tempted to just let it go until I start to feel slippage at high loads, but if I’m out on a ride, could I go another 2000 miles to get home? Also, it “seems” to engage later than it used to, and it does have 160k miles on it. I’d really rather not do it right now, as I’m getting short on time to do it. I welcome any additional input on this.
bdalameda
PaleoCyclist
Salinas, California
Africa Twin
The St1100 clutch usually don't fail right away - the failure mode is usually feeling a slight slip when in 5th gear and accelerating as if to pass a car. Usually simply reducing throttle slightly will allow the clutch to hookup again. I would not be afraid to ride for an extended time if you were to feel the clutch beginning to slip. In most cases the clutch plates are not worn but the clutch springs tend to lose tension over time. If your bike is ridden long distances and you tour mostly the clutch will last almost forever.
kankakee
R1200rt
used to rebuild automatic transmissions. The clutch basket and plates are similar. Hi mileage baskets had a lot of wear where the ears of the clutch plate make contact with the basket. A little wear is ok so and yours may be fine . Just say'in
Kingman, Arizona
2000 ST1100 ABS TCS
004
On my 200,000 mile 91, I replaced only the Springs. Eliminated the slight slippage under load. The old springs were measurably shorter than the new.
And, yes, the right exhaust header must be removed. But, no, you dont need to drain the oil. With the front end elevated just an extra little bit, the oil levelis below the front edge of the clutch cover opening.
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
Check the brass bush and push rod in the lever assembly. Make sure the push rod fits in the side hole of the bush, and there is no debris in there.
paulcb
paulcb
Celina, TX
8735
Thanks John. I assume you're speaking of the bush in the lever. I believe it's good since I replaced it about 20k miles ago, but will look at it closely.
woodybelle
Sonora, California
Paul I have a 1300 but I had the same concern as you but at 85,000 miles. The lever was engaging when it was almost all the way out but it did not slip. I found that the plates were all in spec but at the thinner end and the springs were just in spec also. I replaced the springs and friction plates and now the clutch engages closer to the grip and feels like new.
jfheath
John Heath
2013 ST1300 A9
000679
2570
Yes - if the lever is tight and the clutch is disengaging in the first movement of the lever, there is a chance that the push rod is pressing on the outside of that brass bush when it should be inserted in the hole in one side of the bush. Its an easy assembly error, as you cannot see whether the push rod has gone into the hole or not. I mark the top of the bush with a felt pen to show where the hole is when I am bringing the lever, the bush and the pushrod together.
Smudgemo
Intermodal Man of Mystery
Berkeley, CA
'08 GS / '78 CB550
I dunno, my old man always told me if it ain't broke, don't fix it.
But (no judgement from me) if you are set on doing it, I'd do it soon so you have lots of miles prior to the trip to make sure it's working properly. And I hope your trip is great.
...my 2001 ST1100 with 158k miles on her, commuting being about half of that.
...I wouldn't be surprised if the friction plates where due...
I removed the heat-shields, flanges off the down-pipes, the one bolt holding the collector box (above main-stand) and lowered the forward section with the silencers still attached to the footrest plates
So you'll need the 4 copper crush-gaskets for the down-pipes, maybe some of the short M6 bolts holding the heat-shields (they like to snap...)
Unless badly abused (hence discolored) the steel plates should be OK
Observe their orientation in the clutch basket and ensure to arrange them identically upon installation.
Check basket for wear-marks as shown in @Al st1100 posting, if significant, replace basket too
Soak the new friction plates in the (forthwith used) engine oil before installation.
Paper gaskets for the housing and receiver cylinder, overhaul kits for MC and SC while at it anyway...
And not to forget: proper clutch holding tool, electric impact wrench, torque wrench...
I've ground down an old screwdriver to have a chisel/wedge to unlock the securing lip on the clutch central nut prior loosening; if you can open that without destroying the ring/lip you can reuse the nut, otherwise order a new one
My clutch wrench:
makes this job a breeze...
Working on a bike lift it's like a 4 hour job...
