ST1100 Hoses, Oil Cooler (A and B)
Melbourne, Australia
Honda ST1100 ABS/TCS
4578
I am planning some trips this Australian summer and have ordered OEM radiator hoses, seals and o-rings from Honda. Unfortunatley the oil cooler hoses A and B are no longer available. These hoses are used on all STs up to 1995. After that nothing on the parts list.
Part numbers: 19520-MT3-000 and 19525-MT3-000
Does anybody remember what aftermarket hoses they used? Specifications (ID, OD) would be useful. In an emergency can they be blocked off like in later models?
Regards
Garry
Fort Worth, Texas
91 ST1100/06 ST1300
Regards
Garry
I've replaced all the hoses on my 1991. I was able to find the ones listed as no longer available by matching hoses at local auto part dealers...had to visit two, clerks on duty both places let me fondle the stock behind the counter to match up curves. Purchased some bulk hose of the different ID's also.
It's still doable with a little extra leg work.
Northumberland UK
VStrom 650
"They let me fondle the stock behind the counter".........way too graphic.
kankakee
R1200rt
the good news is that it's not oil but antifreeze hoses. Auto part store should have hoses and adapters. Get the brass or aluminum ones, the plastic ones are crap.
Garry_Coates
4578
Thanks Guys. Can anybody tell me whether Oil Cooler hose A is the same internal diameter as hose B? Would make it easy once hose B arrives in the mail to atleast confirm what I will be looking for.
Regards
Garry
Garry_Coates
4578
Thanks John, the two cooler hoses look very similar (in pics) but are priced differently. I am just wondering whether an oil cooler B hose would work for an A hose? B hoses are still available.
Regards
Garry
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Hm... I think one was (is) longer than the other. I don't remember if they were preformed. Sorry. When you get the one OEM you can measure the ID and get a suitable aftermarket for the other.
Garry_Coates
4578
Thanks John, if one is longer or shaped different it is not by much. But being short 1 cm is no better than being short by 10cm. Oh for the days you could go down to the wreckers and search thru parts yourself. Now you have to wait at the counter while a disinterested worker finds the first thing he can sell you.
Regards
Garry
Garry_Coates
4578
Feedback for future reference: These hoses ID=6.3mm OD=13.3mm.
HOSE, OIL COOLER (B) 19525-MT3-000 looks to be the right shape to also replace HOSE, OIL COOLER (A) 19520-MT3-000 once it has been shortened.
The alternative is Gates heater hose part number 28407. Best buy 1 metre for two hoses to allow for the bend.
