hi red oneSo that would make sense the hot coolant would flow into the reservoir but since cap loose no vacuum to pull it back into radiator. Still kinda puzzled that no coolant seeped from the loose cap on the thermostat housing. Who knows but glad you are working towards a resolution.
it's simple question.
if CAP tightened loosely, red circled sealing still effective, no LLC leaks.
while the orange circle shows pressure spring, it opens LLC pressure at 1.25kgf/cm2.
however loosely tightened CAP cannot apply designated spring force, that's why LLC overflows much earlier timing.
though the loose extent is pretty small, overflow occurs. red circled sealing is normally designed quite tightly as not to leak from CAP.
well , actually i am very ashamed, i know the phenomenon very much well as an RADIATOR engineer, how come i do that on my bike, very embarrassing.
