Hi everyone,
New to the forum here. I just picked up a beautiful 1992 ST1100 with 31,000 miles on it. Other than some minor cosmetic damage the bike looks very clean and in good shape.
When I picked up the bike it was running but had a bad battery. When I got the bike home I put the battery on the charger and washed the bike. I used a pressure washer and the left side cover was off. Once clean I dried the bike with the blower. I put the battery back in and found it was dead. I then jumped the bike with my truck (running) and the bike would crank but wouldn't start.
I pulled a plug and found no spark; I confirmed that the other cylinders also had no spark.
So far I have tested the following and they all seem to be working fine..
-kill switch
-side stand switch
-neutral switch
-BAS bank angle sensor
-secondary resistance on ignition coil
-clutch safety switch
-checked all fuses
I also noticed the red wire bypass has not been done but there is no sign of excessive heat or corrosion or damage of any kind.
I am at a loss at this point. I ordered a new set of plugs with for the distant chance that they are fouled. I think the next step I will take is to remove the forward cowlings and do the full tests on the ignition coils and the pulse generator coils. I will also inspect the wiring harness carefully for faults.
Any input anyone has would be very welcome! The bike was running when I picked it up hours earlier so logic says it has to be something I did when I got it home.
Andrew.
-kill switch
-side stand switch
-neutral switch
-checked all fuses
Andrew.
