I have replace brake piston seals and pads and I am unable to bleed the 2 outer pistons operated by the front lever, is there a problem with the proportional valve, if so is there a fix?
Michelle
Michelle
https://www.st-owners.com/forums/showthread.php?2349-ST1300-Brake-Proportioning-Control-Valve-(Bike-Years-2003-2004) This is the recall info.Its a 2003 I have had it from new and wasn't informed about a recall about that problem as I think it could be something to do with it.
The rear caliper thats operated by the front lever, the foot pedal bleed ok.
I did use a proper suction bleeding tool for the job as I have changed the fluid before.
