I. With initial cold-start, ECM just blindly injects petrol and fires spark to get bike started. There's additional cold-start enrichment amount of petrol based upon IAT and ECT readings. Can be +25% to account for lower vapourisation of petrol at lower temperatures.So my question is, what is the normal warmup sequence that may be starting to fail? I should add that it's perfectly fine the rest of the ride.
II. Once engine is spinning, ECM inspects TPS, MAP sensor and RPM readings to look up 3D maps and arrive at proper injector duty-cycle and ignition-advance.
III. When ECT indicates engine is partially warmed up, cold-start enrichment is turned off and ECM consults O2-sensors for fuel-trim.
This might be time when you're noticing unruly behavior from engine. Might want to measure ECT, IAT, TPS, MAP and verify they are reporting signals appropriately. Also verify O2-sensor signal with oscilloscope. Wonky O2-sensor signals can trick ECM to significantly throw off AFR and cause stumbling.
