Could have been even more interesting if they had stuck two CX500 or 650 engines into a V4.... the 500 was an 83 degree v twin and I have no memory of the crank part of that design, I just know it worked!
Maybe two NT650 or 700 engines for an across the frame V4?
Not sure that Honda ever take an easy route in design.....
Recall that the CX engines used pushrods to actuate its overhead valves (OHV) rather than the double overhead cams (DOHC) of the ST, VF and VFR V4s (did I miss any Hondas?). The NT and its derivatives were single overhead cam (SOHC) designs, as was the final VFR1200 engine which used Honda's Unicam design. It's generally accepted that pushrod motors deliver lower performance than overhead cams all things being equal due to the greater mass and inertia of the intake/exhaust hardware. Of course there are exceptions to this rule... Detroit still has a thing for extracting a lot of power from ancient pushrod engines, not to mention certain heavily breathed upon Milwaukee twins.
If I recall correctly, Honda's reason for using pushrods on the CX was to keep the engine compact and the crank to top of the valve cover short.
The CX was also the basis for one of the more unusual engine adaptations in racing. Wanting to enter AMA Dirt Track Racing, and finding a competitive advantage in delivering power offered by V-twins with transverse cranks and chain drives ala Harley, the guys at American Honda took a CX engine with its longitudinal crank and rotated it ninety degrees and equipped it with a chain drive!
Indian isn’t the first company to take a stab at knocking Harley-Davidson from the top of the dirt-track hill. First, there was the Honda RS750 of the 1980s.
www.cycleworld.com
It was a mongrel, but it got the attention of Japan and a proper Harley competitor was designed and delivered to Honda several AMA Flat Track championships at the hands of Ricky Graham and Bubba Shoebert.
