Funny, I had a mechanic in the local Honda shop tell me the exact same thing, after replacing a guys master cylinder housing, front brake lever, hose(s), rebuilding the master cylinder on the handlebars, replacing the pads, replacing the seals in both front calipers, and charging the guy a small fortune etc.
What was amazing is they missed checking the most simple things.
As far as your disagreeing with me, no worries there, as we are both trying to help this guy etc.
But what your not understanding, or what I'm not explaining well enough is, once you apply pressure, and things bind up, they usually remain in that "crooked" position, until they are moved around, either by removing the pressure, hoses, or tapping things.
If the bracket or clip is damaged , bent, rusted, or dry, and pressure causes things to cant, thus binding the brakes up, then removing pressure, to allow it to be free again, don't be so sure that its a pressure issue and not a binding issue.
And yes, a damaged or failing SMC can cause the front brakes to act up as well.
Remember the brakes are linked.
If the return port is clogged up (screen/cartridge) on the back side of the SMC, it will keep building pressure in the entire system (path of least resistance) and cause binding somewhere.
Remove the SMC from the from a possible cause and see if the other brake still binds and locks up, I'm guessing it won't.
Has anyone checked the rear stopper bolt?
It could be loose, allowing the caliper to rock forward, and press down enough on the rear line to cause issues as well.
For the OP, a couple other things to check for....
Did someone over grease the guide pins, causing suction, and not allowing them to release?
They should have only a very light amount of grease on them?
So far nobody has said anything about rebuilding the rear master cylinder unit behind the right side step?
Linked system, you have to check everything.
