I received your part and I'll be working on duplicates this week. Thanks
Ah, this is exactly what I was hoping to find, the dimensions of that civilian seat bracket. It doesn't seem to be available separately from the seat. I don't want to buy a new seat for the $3.99 part. Should be easy to create one, as you said. How did yours work? If you have the info, I just need to know:
1. the precise width (or is that length?) of the bar between the bracket arms
2. distance from the base of the bracket to the crossbar
3. do the bracket arms bend down at 90 degrees from the base, or is there an offset angle?
thanks, Alan
Forgot .. would also help to know the diameter of the crossbar, although that's not really important -- anything around 8mm ought to be fine.
Any info is greatly appreciated!
