One might also run into trouble aligning the steering-limiters as well as the lock due the different height...The fact that an improperly selected tapered roller bearing used with the OEM seal doesn't work does not imply a general problem with the use of a tapered roller bearing in a steering head.
So careful measuring and checking is advised when going to install non-OEM bearings...
BTW: can't see an issue with loose ball bearings, just stick them into the races with marine grease and don't tremble while inserting the steering stem...
