ST1300 Throttle
Frankfort, Kentucky..
ST1300 2008
Just traded my ST1100 for a ST1300.. First thing I noticed it the throttle works what I consider hard for a throttle! It has a cruise control on it..
Any help on why that is before I dismantle and try to determine cause?
Rochester Mn
2014 FJR ES 2009 WEE
I'd first check that there's a tiny bit of play in the cables....otherwise probably the cruise control....what kind is it? ff....also if it has risers of some sort make sure the cables are routed properly and theres enough slack in them.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
Take a look at where the cruise control ties into the throttle body as it sounds like something is binding up. It should be about the same as the 1100.
Rochester Mn
The reason I asked is because bar end throttle locks can stick....good luck on finding the problem and implementing the cure.....ff
